Turbocharger scheme and regulation explained
2024-03-15
How the tubrocharger works, what is WasteGate and why is the bypass or blow-off valve needed? Below this text is basic schematic of turbocharger control. Of course, this may vary for some vehicles, so let's say it's like a 2005 Volvo V70 T5. On…
Známé chyby po nahrání optimalizace výkonu
2022-06-13
After performing engine optimization, the following errors are 95% likely to occur, which are only visible after loading any diagnostics. These are engine unit software checksum - ECM. The original checksum of the engine unit is stored in the…
Big brakes upgrade for S/V60
2021-06-27
Rebuild kit for the front brakes in Volvo S/V60s with the original diameter 300-mm. Parts used from V60 D6 with a diameter 336-mm. Part numbers needed for complete rebuild: 2 pcs belt holder: 8603758 Brake calliper PP: 36000375 Brake calliper LP:…
VEA unlock - tune - DENSO
2020-07-05
How to unlock Volvo VEA ECM with VDASH? Follow this tutorial! If you dont have UCBP and you want to tune your car, you can build your own UCBP - HERE or just buy ours from our e-shop - HERE Supported HW numbers: …
Boost pressure sensor clogged - diesel VEA and latest D5 5-cyl.
2020-01-17
If you have diesel car with 5-cylinder engine from 2012 or newer, or you have 4-cylinder VEA engine, then you need to clean the boost pressure sensor every 30-80.000-km. Otherwise your engine power will rapidly decrease and you can expect the engine…
EGR blanking plate - Euro3 D5 - D5244T/D5244T2
2019-11-04
If you load EGR OFF software into Euro3 engine (D5244T (120kW) or D5244T2 (96kW)) with VDASH, you must install EGR blanking plate according the pictures below: You can buy the blanking plate in our e-shop.
ECM PIN decoding (applicable only for P3, SPA/CMA and P1 MY2012+)
2018-11-10
PIN decoding for ECM - motor unit - chiptuning EDC16C31 in platform 3 - 5-cyl diesel Euro4 engines - if you need to decode this unit, use our contact form or contact our dealers from VDASH PRO or VDASH PRO VERIFIED.- or send the ECU to us https:/…
